aft bilge pump float switch
I have a 1987 3300 open. The aft bilge has stopped working automatically and I think there is a short in the live connection to the float switch. Where does the wire from the float switch connect to remain live when the battery switch is off?  It doesn't appear to be connecting directly to the battery and the electrical schematic is not enlightening either.
I think you will find a 10 Amp push button breaker marked Aft Bilge with a brown red wire and it is always hot, coming from the hot side of the main breaker on the DC panel. This B/R wire should go directly to the Aft float switch. Capt. George
Thank you capt George.  I have found a revised schematic which makes more sense as the float switch wire appears to go to the battery switch.  Is the push button breaker on the panel to the right of the wheel.   If not, where is it located? If so, is there a separate breaker for the manual aft bilge switch?
Every boat is different. The push button breaker for the float switch is usually on the AC/DC main panel. The manual aft switch at the helm will have a separate breaker. Capt. George
Thanks for your advice.  Float switch is now rewired and working again.
  39 Sovran VacuFlush Pump Access Euphoria38 6 2,167 07-26-2026, 10:26 AM
Last Post: Euphoria38
  2900 open - a/c water pump not running North000 2 1,375 06-22-2025, 02:18 PM
  [Tiara Open] Shower sump pump lakesidevu 2 1,683 05-26-2025, 08:29 AM
Last Post: TenBayFive
  A/C raw water pump runs very hot Joeboch348 3 2,221 05-20-2024, 10:10 AM
Last Post: Sapphire
  41 Open AC water pump vapor lock esf 3 2,124 08-07-2023, 04:07 PM
Last Post: esf
aft bilge pump float switch00
