Teak flooring care as well as the hardwood on the walls
I have a 2006 Sovran with the teak and holly flooring, I am assuming all I need to do is apply some teak oil (starbright?) to the floor and should be good to go. I also have wood on the walls, I think they are sealed with some sort of Polyurethane, so I guess a good wipping is all that is needed? or are the walls not sealed and maybe need teak oil as well??
Thoughts?? TIA
Teak oil will not penetrate into a surface sealed with polyurethane such as your flooring. I would suggest a light sanding with 200 grit paper, a through wipe down and a coat of satin varnish. For inside varnish I have had good luck with Minwax Satin Varnish and a VERY good bristle brush or foam brush. On unvarnished teak I like Watco Teak Oil, both available at Lowes. Apply it with a dust free rag. Capt. George
Unless you are repairing a scratch or gouge or completely refinishing, I would refrain from sanding the interior wood either cabin sole, paneling or trim. Yes, they are sealed with a Urethane and Teak oil is just going to make a mess. I would wipe the walls and trim down with Pledge or equivalent. Pledge is going to be very slick if you put it on the cabin sole. I would simply wipe down the cabin sole with a Murphy's oil based soap and water (for wood floors - follow the directions on the product) or equivalent and dry thoroughly.
Good Luck!
We use Murphy's Oil Soap wipes on both the floor and walls.  They are easy to use and do not make the floor slippery.
John
36 Sovran, Cummins QSC
(12-02-2014, 10:22 AM)jhhall Wrote: We use Murphy's Oil Soap wipes on both the floor and walls.  They are easy to use and do not make the floor slippery.
thanks Guys!!  I thought they were sealed, but thought I would check first before doing anything.  I hope it is a very long time before I touch it with a sander!!!
The wipes sound like a good idea! Easier than breaking out a bucket and mop!
  Tiara flooring repair neto 5 5,611 01-18-2022, 06:45 PM
Last Post: MC1600
  teak steering wheel patriotbuilder1 3 5,860 12-20-2017, 06:02 AM
Last Post: bruce33
Teak flooring care as well as the hardwood on the walls00
